1986 Honda Prelude Lights Stay On
LODYFRANK
My 1986 Honda Predule Si has the side, rear and licence plates lights come on when I turn on the ignition switch to the assy and on positions with the light switch in the off position.
Any recommended fixes?
Jun 27, 2007 at 1:50 AM
BRUCE HUNT
  • 3,754 POSTS
Two things come to mind. One is to take the switch apart for the lights. I have had them apart several times and they really are rather simple. I suggest if you do this to have an other set of eyeballs watching to see what goes where. There are not a lot of pieces that will fall out Most of the stuff is common sense type stuff and a good cleaning might be just what is needed.
BEFORE taking the thing a part, the other suggestion is to go over the grounds on the vehicle. This might scare you but on a typical Honda there are upwards of 70 grounds on the vehicle. Those grounds get corroded and rusted. Look at those as well. I can't tell you where to look but use common sense.
Jun 27, 2007 at 1:58 AM
LODYFRANK
I think you may have hit it on the head.
I was rewiring my radio and may have it grounded to the wrong source.
I'll let you know if that was the case.
Thanks for the directions
Jun 27, 2007 at 6:12 AM
LODYFRANK
Disconnected the ground wiire and it solved the probelms.
Again thanks :D
Jun 27, 2007 at 11:55 AM
Suggested Repair
Check for an incorrect radio or accessory ground. Disconnecting a misrouted ground wire stopped the side, rear, and license-plate lights from coming on with the ignition. If the issue returns, clean the light-switch contacts and inspect corroded body grounds.
Conversation Summary
A 1986 Honda Prelude Si had side, rear, and license-plate lights that came on in the ignition accessory and on positions even with the light switch off. The expert suggested inspecting and cleaning the light switch and checking corroded grounds. The owner had recently rewired the radio and found a ground connected to the wrong source; disconnecting that ground wire resolved the problem.
