1991 Honda Prelude shifter lock
112,000 MILES • 4 CYL • 2WD • AUTOMATIC
PHIKPO
shifter or my car locked . how can I released the shifter
Nov 27, 2008 at 6:48 AM
KHLOW2008
  • 41,812 POSTS
Hi phikpo,
Check if the brake lights are working. If not, you need to check for a blown fuse or a bad brake switch, located on the brake pedal support.
There is a key slot on the gear shift panle, insert the ignition key and push in, shift to neutral before starting. Caution, you might be driving without any brake lights if you use this emergency shifter release.
Nov 29, 2008 at 10:10 PM
