I dont think you can adjust it. I know I can't on the two CRV's I own. Honda uses little 6 mm screws to secure the tps to the throttle assembly that twist off and present a rounded looking device holding the thing on. You can use a small chisel and hammer and unscrew these screws but you do not have an elongated hole in the tps to adjust. If the tps is malfunctioning, you have to buy a whole new throttle assembly just to get the tps. Honda does not sell it separately. I'll do some more research Monday on All Data and see if my memory is correct.
SPONSORED LINKS
Saturday, April 14th, 2007 AT 9:01 PM
