My idle varies from day to day or even while I am driving, from as low as 400rpm or 700rpm to 900, 1100 or 15000rpm.
Regularly the car won't start, it has stalled when stopping at a stoplight, and once when going over a speedbump at a low speed.
Under advice from mechanics I have recently replaced fuel pump, ignition coil, ignition switch, air and fuel filters, distributor cap and wires (tune-up).
Most recently it was tested to have spark and fuel pressure at the time that it stalled.
Check engine light indicates MAP sensor is faulty.
Tomorrow I will test the MAP sensor and also try to plug in a computer from a friend's 89 Prelude.
Any other ideas on what could be the problem?
SPONSORED LINKS
Saturday, December 9th, 2006 AT 6:44 PM
