1999 Honda Prelude Feel like it's about to die on me
BLONGBOY
  • 1999 HONDA PRELUDE
  • 4 CYL
  • FWD
  • MANUAL
  • 136,000 MILES
My car is fine when i'm driving, the problem is when I stop, my car start to shake then my check light flash, my mufflers sound like it's about to die, off and on sound.
when I check under the hood their water drop everywhere and i'm also loosing antifreeze everytime I driver.
thank you
-Blong
Monday, May 17th, 2010 AT 6:49 AM
  • 31,937 POSTS
Hi there,
Thank you for the donation,
You have a number of things to do here, first is to get a scan done to identify the set fault code indicated by the check light, next have a cooling system pressure test done to locate the coolant leak and also have the base idle control checked, this may be tied in with the check light code, start here and report your findings for further assistance.
Mark (mhpautos)
Monday, May 17th, 2010 AT 7:06 AM
