1995 Honda Prelude
XTREME2009
  • 1995 HONDA PRELUDE
  • 4 CYL
  • AWD
  • 140,000 MILES
When I am driving down the highway my car will pull me into the next lane, but yet the steering wheel has not moved. It is not just pulling to one side like it does when the alignment needs aligned. This problem is way worse, like it doesnt matter what you do with the steering wheel the car will just take you into the next lane with out notice and almost impossible to steer it to keep it from taking me into the next lane and possibly wrecking
Saturday, May 9th, 2009 AT 12:30 PM
TED-E-DEE
  • 109 POSTS
I think there is a mistake on car description. You must mean 4-wheel-steer, not 4.W.D. Anyway, ck. Your susp, especially sway bars & sway bar links. Ck. Control arms & bushings. Have the 4-wheel-steer system checked by a professional. Ck. Tie rods & pwr. Steer rack & pinion system. Ck. Strut mounts, upper & lower. An issue like that should be somewhat noticeable. Tires all good? Ck. Easy things 1st, then move on. Good luck !
Tuesday, May 12th, 2009 AT 1:07 PM
