1993 Honda Prelude
1993 HONDA PRELUDE
160,000 MILES • 4 CYL • FWD • MANUAL
NEEDTOTALK7
The other day my son took my car and didn't notice that it overheated after the heater hose sprung a leak.
The next day i tried to start it and it would that when i noticed that it was missing water long story short i changed the heater hose refilled the radiator checked for leaks and the car still won't start up. A friend of mine suggested that it might be the distributor cap but i don't want to mess with it just yet. So I would appreciate it if you could help me
Dec 30, 2009 at 6:15 AM
KHLOW2008
  • 41,814 POSTS
Hi needtotalk7,
You would need to test what is missing causing the problem.
1. Ignition spark.
2. Fuel supply.
3. Mechanical.
Here is a link from which it explains how to go about checking.
https://www.2carpros.com/kpages/first_things.htm
Hope the overheating has not damaged the head gaskets of which the compression would be low and you would not be able to start the engine.
Dec 31, 2009 at 1:32 AM
