1985 Honda Prelude No heat
1985 HONDA PRELUDE
200,000 MILES • 4 CYL • FWD • MANUAL
BPUIDA
My son just bought a 1985 Honda Prelude it doesn't warm up on a cold morning. The radiator is full. The engine temperature doesn't go up very much even after driving for awhile. I suspect it is the thermostat. What do you think?
Jan 9, 2010 at 1:19 AM
KHLOW2008
  • 41,814 POSTS
Hi BPuida,
Yes, most probably the thermostat has been removed or is stuck in the open position.
When engine is cold, remove the radiator cap and start the engine. Note the coolant inside the radiator neck. If the coolant moves continously, the above is true. If the thermostat is good, the coolant should be stagnant for a few minutes before it starts moving.
Jan 11, 2010 at 3:44 AM
