I just got a 1992 Honda Prelude S with an F22A6 2.2 litre engine. It's a 5 speed manual, and It started fine the day I got it. I started it about 10 times no problem and drove it about 100 miles, also no problem. It sat in my garage for about a week while I was changing 2 tires, added a cv axle nut, and two mirrors. The only other thing I did was clean out the throttle body with carb cleaner because the throttle was slightly sticking.
Here's my problem: The car won't start now, and I replaced the spark plug wires and the plugs are giving off a strong blue spark. The timing belt looks like it's in time, the distributor is fine, the fuel pump primes and I can smell gas when the I turn the engine over. The starter turns the engine over, turns the flywheel and the timing belt, but it doesn't seem to be firing up. I tried to push start it a few times, and all I get is a few clicks just like I get when I try to start it, but still no ignite. Please, any suggestions will help tremendously.
SPONSORED LINKS
Saturday, March 7th, 2009 AT 11:25 PM
