Hi l0wrider,
This is not an easy task and you would need to remove the air cleaner assy to allow access.
Some slight bending of the hose might be necessary to get it into position and always get the joint at steering rack into position before you attempt to tighten anything.
SPONSORED LINKS
Tuesday, February 16th, 2010 AT 7:30 AM
