1988 Honda Integra Cranks No Start
HONDA
ASHMRA
Hey,
I own a Honda Integra 1988 SX16 model, automatic tranmission with a mileage of 2 540 431km, however it will not start. i turn the key in the ignition and the motor turns over, however it will not start. My dad thinks it may either be a fuel or electrical problem...I thought maybe you could help me.
Please answer my question asap as I need to get my car up and running.
Jul 15, 2007 at 2:35 PM
BRUCE HUNT
  • 3,754 POSTS
You dad is a wise man and it is either electrical or fuel related. What else could it be. So. Have a check for spark at the plugs. No spark, we work in that direction. No fuel being delivered to the cylinders we go that route. You need to determine which direction we follow.
Jul 19, 2007 at 3:57 AM
Suggested Repair
Check for spark at the spark plugs. If there is no spark, diagnose the ignition system. If spark is present, check whether fuel is reaching the cylinders and follow that path.
Conversation Summary
The owner of a 1988 Honda Integra with an automatic transmission reports that the engine cranks but will not start. The expert says the cause is likely electrical or fuel-related and advises checking for spark first, then checking fuel delivery if spark is present, to determine which system to diagnose.
