1999 Honda Accord Starter Diagnosis
1999 HONDA
MICHAELS1LAW
I'm preety sure my starter has gone out but am not 100% sure.I heard a rumor that If I take screwdriver and place in a piticular spot the starter,the car either
turns over or not turn at all meaning the starter is bad. Please help with this problem before I start loosing money by not traveling.
Thanks!
Nov 22, 2006 at 12:23 AM
BRUCE HUNT
  • 3,754 POSTS
Ensure that the battery is good and fully charged. Then using a volt-ohm meter check the voltage at the starter. Got 12 volts? Are the connections secure? Is there any sound from the starter? If the thing is dead does a rap on the side produce any results? Has it given you any indication that it was going?
They aren't that hard to replace and I would suggest a remanufacturered replacement from a good source.
Nov 22, 2006 at 2:38 AM
GARFIELD
  • 197 POSTS
You can take a remote starter( basically a wire with an allagator clip on each end and a pushbutton to activate the starter( a poor mans alternative is a long peice of heavy gage wire with allagator clips attached to the end, if you use this method connect to the s terminal on the starter first then monentarily touch the other end to the positive terminal on the battery) DO NOT KEEP IT ON THE POSITIVE TERM FOR MORE THAN A FEW SECONDS ALL YOU ARE DOING IS SEEING IF THE STARTER WILL TURN OVER!!!!! Connect one clip to the positive term of the battery and the other to the s terminal on the starter. When you depress the push button the starter should turn over. If it doesn't the starter is most likely bad. You can pull the starter and have it bench tested at most every auto parts store.
Dec 3, 2006 at 11:50 AM
CAPTAIN HANK
  • 32 POSTS
you didn't explain why you think the starter is going bad. Let me guess....when you turn the ignition key to start all you hear is a series of clicking noise..or the starter sounds as if it is straining trying to turn the motor. And if you hold the key in the start position long enough the engine finally turns over. These are signs the starter needs replacing. Check for good voltage/good battery/connections etc. Remember your starter is eight years old now.
Dec 7, 2006 at 5:59 PM
Suggested Repair
Confirm the battery is fully charged and connections are secure, then check for about 12 volts at the starter. Briefly energize the starter S terminal or have the starter bench tested; if it does not crank, replace it with a quality remanufactured unit.
Conversation Summary
The owner of a 1999 Honda Accord suspects a failed starter and asks about a screwdriver test. Experts advise verifying battery voltage and connections, listening for starter response, and using a remote starter switch or a brief heavy-gauge wire test at the S terminal. If the starter does not turn, it is likely bad and can be removed for bench testing and replaced with a remanufactured unit. Clicking, straining, or delayed cranking are also cited as signs of starter failure.
