Approximatley how much would it cost?
HONDA
TRAVISAUERBECK
:? Would anyone know how much it would cost to replace my valves, and i was wondering if that could be whats causing my care to totally drop off all rpms when i slow my car down to a stop, and the proper oil to use for my Honda?
May 1, 2006 at 2:09 AM
LOSONE
  • 1,616 POSTS
A valve replcement is not a usual repair unless you have broken a timing belt.
Explain the RPM drop off a little better. How many miles on the Honda and what engine and tranny.
Under 150K use 5W30 Castrol GTX over use 10W30 high miles Castrol.
May 1, 2006 at 6:35 AM
TRAVISAUERBECK
thanks for the input...ill try and explain the valve problem a little better....in a few days...
May 2, 2006 at 4:10 AM
