1990 Acura Legend ABS Light On
HONDA
GOTHAMELEX
  • 6 POSTS
Greetings. I have same problem. Same symtoms I gues. I find that my "Anti-lock" light doesn't come on till I start moving. This I think is due 2 a possible wheel sensor problem as was stated. I 2 have the brake squeal problem...after less than 5000mi. Inytresting that Honda/Acura have such inadequate brakes...really small pads.
Jan 24, 2007 at 4:53 PM
DODGER#1
  • 9 POSTS
1990 Acura Legend V6 2.7L: Hi i have this problem that when i start my car and as soon as i step on the brake and put it into drive or reverse the anti-lock light comes up. I did a brake change about 2 months ago. So can u guys help me out? Thanks.
Dec 13, 2006 at 6:38 PM
BRUCE HUNT
  • 3,754 POSTS
Have someone give you a hand by putting foot a brake pedal. Check the brake lights on the vehicle.
Dec 13, 2006 at 11:45 PM
DODGER#1
  • 9 POSTS
The Brake Lights are fine and they alll work.
Dec 14, 2006 at 7:50 AM
BRUCE HUNT
  • 3,754 POSTS
I assume that the brakes are working fine for you and that it seems normal. Right? You have more than likely got a wheel sensor that has failed.
Dec 14, 2006 at 8:44 AM
DODGER#1
  • 9 POSTS
The brakes are working good but what i have notice is that my brake pads are wasting very fast. Like i mentioned earlier that i had made the brake change and now the brake are squeaking like if they are in need to be replaced.
Dec 14, 2006 at 9:19 AM
GOTHAMELEX
  • 6 POSTS
BRUCE HUNT
  • 3,754 POSTS
Both of you need to look at the pads and determine if all of the wheels are wearing uniformly. You could have a defective caliper.
Jan 25, 2007 at 8:06 AM
Suggested Repair
Confirm the brakes operate normally and the brake lights work. Inspect the wheel speed sensors for a failed sensor, and compare pad wear at all wheels; uneven or rapid wear and squealing can indicate a defective caliper.
Conversation Summary
On a 1990 Acura Legend, the ABS light comes on after the brake is applied and the transmission is shifted into drive or reverse. Brake lights work and braking feels normal, but pads wear quickly and squeal soon after replacement. The expert said a failed wheel sensor is likely and advised checking whether all wheels wear evenly, which could point to a defective caliper. Another owner reported a similar ABS light that appears only after moving, plus early brake squeal.
