Honda A/C No Power
HONDA
RAVNEET
ok like i mentioned in the previous post my a/c doesnt get cold anymore and it was due to the compressor ( i think ) not gettin any power from the A/c unit..... i replaced the whole A/C unit and again not as cool...took it to a repair shop and they told me its not getting power..... so again and to replace the unit ( i think it wasnt compatible wit my car ), so i replaced the unit again with the right one and im still having the same problem what can be causin it not to get any power??? can it be the a/c harness??? please hlep if u have any questions just ask
Oct 4, 2006 at 9:31 AM
BRUCE HUNT
  • 3,754 POSTS
Well I am not sure about the wiring scheme on the harness but I would think that going to work with a meter to test voltage coming from the harness is where I would step next. One of the wires in the harness has to be delivering 12 volts of current when the A/C is called for. A repair manual usually has the schematic in it. Good investment!
Oct 5, 2006 at 12:18 AM
Suggested Repair
Test the A/C harness with a meter for 12 volts on the power wire when the A/C is requested, and use a repair-manual wiring schematic to identify the correct circuit.
Conversation Summary
A Honda owner says the A/C no longer gets cold and believes the compressor is not receiving power. The A/C unit was replaced twice, once possibly with an incompatible part, and a shop confirmed there is still no power. The expert recommends checking the harness for 12 volts when the A/C is commanded and consulting a wiring schematic.
