2001 Honda Logo Grinding Noise
2001 HONDA
SUPERIORNZ
Hi, i own a 2001 honda logo auto, 114,000 K's on it and i dont know where the noise is coming from...
it makes a very bad griding/groaning noise when i take slow right turns on the front left wheel... When i go straight or turn left its fine, only when i turn right it makes the noise... its worse at slow speeds but when im going faster the noise is a faster griding noise....so its also speed related. Few mechanics tell me its the wheel bearing but they say they not 100% sure. What do you think it might be? thanks...
Sep 22, 2006 at 3:36 PM
BRUCE HUNT
  • 3,754 POSTS
The noise is a CV axle. Check to see if a boot on the CV axle is ripped open. There are two CV axles and they make up the entire front axle system with the tranny in the middle. The axles can have up to 3 boots (rubber flexible covers) on them that cover flexible joints. However, if the boot wears out and opens up the grease that lubes the joint escapes and eventually the grit of the road and friction will take out the bearings. You may have to replace one or both. Check them both.
Sep 25, 2006 at 11:48 PM
Suggested Repair
Inspect both front CV axle boots for tears. If a boot is open and grease has escaped, replace the affected CV axle, checking one or both as needed.
Conversation Summary
The owner of a 2001 Honda Logo reports a grinding or groaning noise from the front left wheel during slow right turns that also changes with speed. Mechanics suspected a wheel bearing but were not certain. The expert identifies a CV axle as the likely cause and advises checking both front CV boots for rips, then replacing one or both axles if a joint has lost grease.
