1990 Honda Charge Light Flicker No Start
1990 HONDA
FKBSAR
Two weeks ago I had my alternator replaced. Yesterday while driving I noticed that my speedometer dropped and then returned to its original place and then the charge light flickered and then went out. This happened twice within an approx. 3 block area. I made it home and turned the off. Later I tried to start it and it gave a short impression that it was trying to and then click click - nothing. The same thing happened this morning. What kind of possible repairs am I looking at?
Mar 13, 2006 at 2:54 AM
BRUCE HUNT
  • 3,754 POSTS
Check connections and main relay. Also, check to make sure that when they hooked up the new alternator that all of the grounds are still securely attached. The grounds are very important.
Mar 13, 2006 at 9:59 AM
Suggested Repair
Check the electrical connections and the main relay. Confirm that all grounds were securely reattached when the new alternator was installed, because the grounds are critical.
Conversation Summary
The owner of a 1990 Honda had the alternator replaced two weeks earlier. While driving, the speedometer briefly dropped and the charge light flickered, then went out, happening twice over a short distance. After the car was shut off, it would not restart and only clicked. An expert advised checking the connections and main relay and confirming that all grounds were securely attached when the new alternator was installed.
