1996 Honda Accord Cranks No Start
1996 HONDA
NATTYB4KSU
  • 5 POSTS
I need to know where the ignition switch is located and also if you know how to determine if it's out? Also how you can tell if your fuel pump is out?
Thanks
Apr 12, 2006 at 6:37 PM
LOSONE
  • 1,616 POSTS
The switch is behind the area where the switch is located on the column. You didn't mention the problem but I think you may have a bad EFI relay. Let me know some more symptoms.
Apr 13, 2006 at 1:46 AM
NATTYB4KSU
  • 5 POSTS
My car will turn over but it won't start. It doesn't sound like it normally does when you go to start it.
Apr 13, 2006 at 7:19 AM
LOSONE
  • 1,616 POSTS
If it sounds like it is spinning freely, thats bad news, a broken timing belt and it has destroyed valves. That failure occurs about 130K.
Take off the distributer cap and see if the rotor turns when the engine is turning over. If so then you not getting spark and fuel then it is probably the EFI relay which is located on the left side upper dash high in the dash. It is black meteal and fairly large.
Apr 13, 2006 at 9:25 AM
Suggested Repair
If the engine spins freely while cranking, suspect a broken timing belt and possible valve damage, common near 130,000 miles. Remove the distributor cap and confirm the rotor turns while cranking. If it turns, lack of spark and fuel points to the EFI relay, a fairly large black metal unit high on the left side of the upper dash. The ignition switch is on the steering column behind the switch area.
Conversation Summary
The owner of a 1996 Honda Accord asked where the ignition switch is and how to tell whether the switch or fuel pump has failed. The car cranks but will not start and does not sound normal. The expert located the switch on the column and suspected the EFI relay. If the engine spins freely, a broken timing belt may have damaged the valves. Checking whether the distributor rotor turns while cranking helps distinguish that from a no-spark, no-fuel problem caused by the relay high in the left upper dash.
