oil leak
DAVIDNGUYEN
  • 7 POSTS
:( my honda odyssey 1995 when i turn on the engine, oil leak from behind oil fillter .Is it not from oil fillter gasket. What do i need to do?
Feb 13, 2006 at 10:27 AM
FISHERMAN
  • 937 POSTS
where exactly the oil its leaking from?
can you see if its a juction or an screw?
Feb 14, 2006 at 1:33 AM
DAVIDNGUYEN
  • 7 POSTS
[quote="fisherman"]where exactly the oil its leaking from?
can you see if its a juction or an screw?[/quote] :) thankyou i found the clue they have a gasket behine are oil coolling return,before oil filter :D
Feb 25, 2006 at 2:29 PM
BRUCE HUNT
  • 3,754 POSTS
If it leaks in the area of the filter and you possibly did the oil change, check to be sure that there is not a second or old gasket on the filter.
Mar 3, 2006 at 9:28 AM
