2003 Honda Odyssey OIL CHANGE
JETHA
Engine problem
2003 Honda Odyssey 6 cyl Front Wheel Drive 70000 miles
HOW TO CHANGE ENGINE OIL AND WHICH OIL I SHOULD USE 5w30?
Dec 13, 2007 at 3:55 AM
RACEFAN966
  • 5,029 POSTS
Get a drain pan from your favorite parts store, get the oil filter and 5 quarts of 5w-30 oil. Find the drain plug in the bottom of the oil pan and the right size wrench and put the drain pan under it and remove the plug and drain the oil. You may need a filter wrench, remove the old oil filter. Put he some old oil on the gasket of the new filter and screw it back on hand tight, put the drain plug back in (making sure the plugs gasket it good) and tighten it, be careful not to over tighten. Then start with putting 4 quarts of oil in the start the engine one the oil gauge moves or oil light go out then shut the car off and check oil level and top of as needed.
Mar 14, 2016 at 3:25 PM
