2007 Honda Odyssey Pulsating Lights
PATHANIEL
  • 2007 HONDA ODYSSEY
  • 6 CYL
  • FWD
  • 51,000 MILES
Every light inside and outside of the van pulsates at idle and any speed. I checked the battery and the charge is good and no problems with starting or the engine running. I then replaced the ELD (fuse / relay box under the hood) and the lights still pulse. I have not changed the alternator because the battery keeps a good charge and the engine runs good. If it is the alternator, can the alternator be rebuilt? If it is not the alternator, what could it be? Thank you for your help.
Friday, August 27th, 2010 AT 1:23 PM
Sounds like the problem is coming from the computer controlled circuit of the alternator's field generation
Friday, August 27th, 2010 AT 11:52 PM
PATHANIEL
Should I replace the Alternator?
Monday, August 30th, 2010 AT 8:45 AM
Bring it in and get it load tested and go from here.
Monday, August 30th, 2010 AT 5:36 PM
PATHANIEL
Thank you for your help, I will let you know the outcome
Tuesday, August 31st, 2010 AT 6:17 AM
