2002 Honda Odyssey Gauge Lights and Parking Lights don't Wo
BPIER
  • 2002 HONDA ODYSSEY
  • 6 CYL
  • FWD
  • 112,000 MILES
I changed out the front driver side turn signal socket and after completing the job, my gauge lights and parking lights don't work. Also, the SRS warning light is now illuminated. I changed the 10amp fuse on the drivers side fuse box (slot 9). This did not fix the problem. It doesn't seem possible that changing the front directional signal socket would cause this problem, but it never happened until I completed this repair. Any suggestions would be greatly appreciated.
Wednesday, December 3rd, 2008 AT 4:58 PM
KHLOW2008
  • 41,814 POSTS
Hi bpier,
I would suggest checking the job that you did again. There is a possibility some shorting had occurred maybe due to exposed or crossed wires.
Check if the bulb socket tabs are touching each other resulting in the shorting.
Thursday, December 11th, 2008 AT 10:15 AM
