Hi timbo211d,
Thank you for the donation.
Do you mean the engine could not be started after replacing the timing belt?
Have you checked what is missing causing the non starting?
Is the Check Engine Light showing?
Here is a link of what to check for if you are not able to start. Let me know what you find.
https://www.2carpros.com/kpages/first_things.htm
Any info on the problem would be helpful in diagnosing the problm.
SPONSORED LINKS
Saturday, November 7th, 2009 AT 11:30 AM
