2001 Honda Odyssey compressor
2001 HONDA ODYSSEY
190,000 MILES • 6 CYL • FWD • AUTOMATIC
WORKDOC
I repaired leak in system, charged up system, ran good for about a week, quit cooling, checked compressor, clutch not engaging, could this be the low pressure switch, if so, I need to know location of low pressure swith, and where can I jumper out the terminals on compressor to make sure it runs?
Jun 23, 2008 at 4:22 PM
KHLOW2008
  • 41,814 POSTS
Hi workdoc,
To apply power direct to the compressor, you can use the clutch relay or at the compressor where you will find a single wire and socket nearby.
As to the pressure switch, I am not sure of location but it should be near or on top of the drier.
Jun 24, 2008 at 3:28 AM
