Hi Nathanr,
P1361 and P1366 are faults transitted by the TDC sensor 1 and 2.
Based on your description, while in heavy rain , water is splashed onto the sensors giving a false reading and the cutting out. I would suggest checking the connetors for water contamination and cleaning them with application of dielectric grease to prevent oxidation which would cause the sensor to fail at a later date.
P0420 means the catalytic converter is not in good condition and would require replacement.
SPONSORED LINKS
Saturday, November 29th, 2008 AT 9:11 AM
