Hi msteven,
There are a few possibilities that can cause the problem described.
1. Faulty PGM-FI main relay. Remove the relay and check if the circuit board has cracked joints. Resoldering would solve the problem.
2. Bad ignition switch. f the dashlighs do not show when the engine stalled, then the ignition switch is most likely faulty.
3. Failing ignition coil. A bad ignition coil would cause weak sparks and this would cause difficult or non starting depending on situation.
When engine could not start, you should check if there is no spark or fuel available.
The following link has some testing procedures that wuld be of assistance to understand what to do.
SPONSORED LINKS
Tuesday, June 16th, 2009 AT 12:04 PM
