Hi mistersq,
The belt is installed after the alternator has been mounted and not before.
I do not understand why you are not able to install the alternator unless it is not of the correct type.
ALTERNATOR
Removal
1 . Ensure you have the anti -theft code for the radio and the navigation system. Write down the
frequencies for radio's preset buttons.
2 . Disconnect the negative cable from the battery, and disconnect positive cable.
3 . Remove the alternator/compressor belt.
4 . Disconnect the alternator 4 -pin connector and Black wire "B" from the alternator.
5 . Remove the mounting bolt "A" and alternator bracket mounting bolt "B". Remove harness
clamp"C" from alternator bracket.
Installation
1 . Install in the reverse order of removal.
2 . Enter the anti -theft code for the radio and navigation system. Enter the customer's radio station presets.
3 . Perform the Powertrain Control Module (PCM) idle learn procedure, and power window control unit reset procedure.
4 . Set the clock.
Wednesday, November 13th, 2019 AT 12:07 PM
(Merged)
