1996 Honda Odyssey Car won't start
BURGEE
  • 1996 HONDA ODYSSEY
  • 4 CYL
  • 70,000 MILES
Engine cut out suddenly. There is no spark at the plugs. I have replaced the distributor cap and rotor arm. The engine is turning over but still no spark.
Monday, May 26th, 2008 AT 4:58 AM
Check for power to the coil, coil's primary and secondary winding resistances, distributor pick-up coil, ignitiion control module and crankshaft position sensor-
Monday, May 26th, 2008 AT 5:05 AM
KHLOW2008
  • 41,814 POSTS
If the engine is turning very fast during cranking, you might have a timing belt problem.
Monday, May 26th, 2008 AT 10:48 AM
BURGEE
Fault traced to spark igniter unit inside the distributor cap. Thanks for everyones help!
Saturday, May 31st, 2008 AT 10:11 AM
