No start and no codes
300,000 MILES • 3.5L • 6 CYL • 2WD • AUTOMATIC
2005HONDAODYSSEY
  • 7 POSTS
I was driving my van when it chugged and stalled. I thought it was a clogged fuel filter so I changed it along with the pickup lines. The engine tries to start but wont turn over. Computer and box show no codes
Nov 12, 2016 at 1:47 AM
HMAC300
  • 48,601 POSTS
try resetting security system this is assuming battery is good. See link.
https://www.2carpros.com/articles/how-to-reset-a-security-system
Nov 12, 2016 at 2:20 AM
2005HONDAODYSSEY
  • 7 POSTS
Battery is at 17 volts, security not the issue.
It is acting like is has no fuel yet plenty is getting to engine.
Nov 12, 2016 at 2:28 AM
HMAC300
  • 48,601 POSTS
scan for codes then battery should not be that high on voltage. it should only be 12.6 or so max voltage with key off. It may be a bad battery.
Nov 12, 2016 at 4:48 AM
2005HONDAODYSSEY
  • 7 POSTS
Sorry typo, battery is 11.7. Also as I stated earlier scan tool had (has) no codes. Had local garage come over with a laptop still no codes.
Engine will crank and attempt start but stalls out like it has no gas, but it does.
Nov 12, 2016 at 5:20 AM
HMAC300
  • 48,601 POSTS
the battery must read 12.4 at the very minimum. charge battery then have it checked for condition including load test. most batteries life is only four years.
Nov 12, 2016 at 7:37 AM
2005HONDAODYSSEY
  • 7 POSTS
Connected battery charger, even with it set to jump it wont start it is not he battery or starter, or solenoid, or fuse.
Nov 12, 2016 at 8:19 AM
HMAC300
  • 48,601 POSTS
you have to charge battery until it gets a reading of at least 12.4 volts any other thing is a waste of time. I think you have a bad battery do as I said charge it and get it tested. because battery is dead security system will engage and will need a reset.
Nov 12, 2016 at 8:46 AM
2005HONDAODYSSEY
  • 7 POSTS
Replaced battery, even though old one not bad. Security not engaged. Still cranks but wont start.
Nov 12, 2016 at 9:49 PM
HMAC300
  • 48,601 POSTS
scan for codes and check fuel pressure with a gauge. check fuses and relays under hood PGM and main relays if you have them.
Nov 12, 2016 at 11:40 PM
2005HONDAODYSSEY
  • 7 POSTS
No codes, checked pressure coming from tank in blew the gauge so my guess is that was a sign there was enough pressure. All fuses and relays are good. it it will crank and chug, but wont run.
Nov 13, 2016 at 12:02 AM
  • 55,732 POSTS
Lets remove one of the ignition coils and check for spark. Here is a guide.
Please let me know what you find.
Best, Ken
Nov 13, 2016 at 2:03 AM
2005HONDAODYSSEY
  • 7 POSTS
Good strong spark.
Nov 14, 2016 at 12:02 AM
  • 55,732 POSTS
Can you check the engine for compression? Remove a spark plug and turn it over. I am wondering if it is a timing belt/chain issue.
Here is a guide.
Best, Ken
Nov 14, 2016 at 1:35 AM
