1995 Honda Odyssey Engine Won't Start
DAVID.LYNN
  • 1995 HONDA ODYSSEY
  • 4 CYL
  • FWD
  • 200,000 MILES
The engine would turn over and start for a second and then it would quit. After a few times it would keep running and run fine until you cut it off. Then for a couple of days it would quit when idling. Now it won't run. It turns over fine and will even run for a second but then it dies out.
Friday, August 27th, 2010 AT 9:11 AM
LEGITIMATE007
  • 5,121 POSTS
At this point you will need to check for fuel and spark to figure out which direction to go. If I had to make an educated guess, I think you may have a spark problem, but cannot be for sure, I have some info to show you how to check. And keep me posted
Friday, August 27th, 2010 AT 9:20 AM
LEGITIMATE007
  • 5,121 POSTS
https://www.2carpros.com/how_to/how_to_test_an_ignition_system.htm
Friday, August 27th, 2010 AT 9:21 AM
LEGITIMATE007
  • 5,121 POSTS
https://www.2carpros.com/how_to/how_to_check_fuel_pressure.htm
Friday, August 27th, 2010 AT 9:22 AM
