1988 Honda CRX No Start
JIMMY-Z
my 88rex hasn't wanted to start, so i pulled the first spark-plug and it was soaked in oil, i pulled the 2nd, dry&ok, 3rd, oily, not soaked like the first, and the last one was dry , my first thought was the rings are shot, granted it's almost 20 years old and 184250 is the mileage, 1.6, 5spd, i put new plugs in and it wont start, and all new plugs were dry after trying to start for 10 min, what to do? I have never changed the fuel pump either???
Thanks for listening. Jim
Aug 5, 2007 at 7:46 AM
BRUCE HUNT
  • 3,754 POSTS
You need to determine if there is spark at the plugs. Could be a coil that is gone. The oil on the plugs, is that on the tip or the top of the plug?
Aug 7, 2007 at 6:16 AM
ITZ_2_EAZY
make sure you are getting spark, could be a bad sensor in the distributor, doesnt have a coil. make sure you here the fuel pump kick on, to make sure it is getting fuel.
Aug 7, 2007 at 10:55 AM
Suggested Repair
Check for spark at the plugs, including a possible failed distributor sensor or ignition coil. Confirm the fuel pump primes when the key is turned on. Also note whether oil is on the plug tips or the tops, since oily plugs may point to internal engine wear.
Conversation Summary
A 1988 Honda CRX with about 184,000 miles would not start. Two spark plugs were oily and two were dry; new plugs stayed dry after extended cranking. Experts advised verifying spark, considering a bad distributor sensor or coil, and confirming the fuel pump kicks on so the engine is getting fuel.
