1989 Honda CRX
89CRX85
  • 1989 HONDA CRX
Engine Mechanical problem
1989 Honda CRX Manual
hello I wanted to see if u guys could help me I have a 89 honda crx si and am replacing the water pump and timing belt the only problem I have is getting the crank bolt off do I clockwise or counter clockwise for it to come off? If u could help me out please its the only thing stopping me.
Monday, February 16th, 2009 AT 2:36 PM
F4I_GUY
  • 3,302 POSTS
You turn it counter clockwise.
If you are doing this with hand tools, you have two choices.
1)purchase a crank pulley holder tool, that will hold the crankshaft and allow you to break the bolt loose.
2)remove the starter and put a pry bar on the flywheel, this will also stop the engine from turning over while you remove the bolt.
If you have an air impact gun that will work too.
Monday, February 16th, 2009 AT 4:18 PM
