Login
Join
Ask a Question
Questions by Vehicle
Repair Topics
Testing / Diagnostics
Repair & Service Guides
Symptoms
Warning Lights
Trouble Codes
How It Works
Videos
Login
Become a Member
Home
Honda
CRX
Engine
Replace/Remove
1990 Honda CRX engine replacement
1990 HONDA CRX
132,000 MILES • 4 CYL • FWD • MANUAL
ELDODGE0
MEMBER
1 POST
how do you pull the engine to replace it with a rebuilt? Step by step please. I've never pulled a fwd engine before. Thank you.
Sep 14, 2009 at 1:51 AM
KHLOW2008
Experienced Mechanic
Hi eldodge0,
If youhave experience with removing and installation of engine, it should be similar.
Only thing that you need to do is to remove the axle shafts and all others should be similar.
Sep 21, 2009 at 8:44 PM
Add image or video
Ask a new question
Engine won't start
Engine has low power
