1987 Honda CRX engine idle
99,000 MILES • 4 CYL • 2WD • AUTOMATIC
FAIRHAVEN
I just bought this car and it seems to have a high engine idle for the auto transmision when stoped. What should the rpm's be when stoped? This is about 1000 rpm's. How does one slow it down?
Dec 19, 2007 at 9:56 AM
BLACKOP555
  • 10,386 POSTS
there is a throttle adjust screw on the throttle body, where the throttle cable connects. simply turn it to reduce speed.
Rpm's should be between 500-700 a bit higher atfirst on a cold start.
Dec 19, 2007 at 11:43 AM
