1999 Honda CR-V Stalling on 3 Cylinders
PAJAMAS
I have a 99 Honda CRV with 84,000 miles on it. It is a 4 cylinder, with manual transmission. I bought it a year ago and I do not have any history on it. For the last month or so it has been stalling occasionally when I slow down or come to a stop. Last week, it starting occuring more frequently, the engine light came on, and it started running rough.
I took it to a repair shop. They did a fuel flush, changed spark plugs, fuel filter, air filter. It was no better. Now I am told one of cylinders needs replacing and that the car is only running on 3 cylinders. Would this make it stall at low speeds? Any help would be greatly appreciated.
Jul 25, 2007 at 11:51 AM
BRUCE HUNT
  • 3,754 POSTS
Yes it would. Dragging a dead cylinder is hard work. Now why is it dead. That is the question. Have a leak down test performed to tell you what is wrong. Pretty darn cheap. Have you check to see that the plugs are ALL getting spark? You could have a power pack that is bad. Does this one have a distributor?
Jul 26, 2007 at 2:05 AM
Suggested Repair
Have a leak-down test performed to find why one cylinder is dead. Also confirm every spark plug is getting spark; a failed ignition power pack or distributor-related ignition fault may be the cause.
Conversation Summary
The owner of a 1999 Honda CR-V with a manual transmission reports occasional stalling when slowing or stopping, which became more frequent with a check-engine light and rough running. A shop performed a fuel flush and replaced the spark plugs, fuel filter, and air filter without improvement, then said the engine was running on three cylinders and one cylinder needed replacement. The expert says a dead cylinder can cause low-speed stalling and recommends a leak-down test, checking spark at all plugs, and considering a bad ignition power pack or distributor issue.
