2005 Honda CRV Windshiel Wipes
2005 HONDA CRV
35,000 MILES • 4 CYL • AWD • AUTOMATIC
C.A.FEY
I have had my car into the dealership four times and the wipers still don't work, at all. They usually work for about a day then stop.
The first time, the fuse was replaced. The second time the wiper motor was replaced. The third time they said they traced the wiring system and they found a wire that was frayed and they replaced that. This last time they said a switch was replaced on the steering column.
Help! I have an appointment to bring my car in again. If that doesn't work, I'm trading the car in.
Aug 15, 2009 at 9:46 AM
KHLOW2008
  • CAR REPAIR CONTRIBUTOR
  • 41,814 POSTS
Hi C.A.Fey,
Thank you for the donation.
If all speeds are not working, it could be caused by any of the followings:
1. Power supply from the # 20 ( 20 A ) to the wiper motor
2. Wiring from wiper motor to column switch.
3. Fauly column switch.
4. Column switch to ground behind the glove box.
Testings would be required find out which of the above is faulty.
Aug 16, 2009 at 1:14 PM
