1999 Honda CRV power steering
1999 HONDA CRV
133,000 MILES • 4 CYL • AWD • AUTOMATIC
TINA2
My car has a rattling noise. Honda says it is the r/s inner rack bushing. I also need rear trailing arm bushings and my outer tie rod ends are bad. They say I only need to replace the power steering rack? Do You think all should be done together? Can the rack just be loose?
Dec 5, 2009 at 11:31 AM
  • 31,937 POSTS
Hi there,
If the rack is loose it will take a mechanic just a few min to tighten it up, if the rack bushes are worn, i would get this done and the other items in one go as it will be cheaper in the long term and it will give you a safer car to drive.
Mark (mhpautos)
Dec 5, 2009 at 11:52 AM
