2004 Honda CRV engine light on
109,000 MILES • 4 CYL • AWD • AUTOMATIC
LWOOLMAN
I started my car after it had been sitting for 24 hours but when I take my foot off the gas pedal it dies. Today it was running for a few minutes with my foot off the pedal but it sounds like the car is going to die again. I also noticed the engine light came on.
On 9/25 I had my car serviced and they recommended a brake inspection next time as they found the brake fluid level to be low. Could this be causing my problem?
[img:6a185107f7]http://www.2carpros.com/forum/automotive_pictures/590166_IMG_6206_2.jpg[/img:6a185107f7]
Nov 7, 2010 at 5:54 AM
  • 75,988 POSTS
Have the computer scanned for code/s-you have a problem within the engine management system that caused the CEL to turn on-This is your starting point of diagnosis,finding out what's going on.
Nov 7, 2010 at 10:30 AM
HONDA TECH 1818
  • 536 POSTS
Most likely the IAC valve is bad.
Nov 7, 2010 at 2:11 PM
