Hi Imad,
When you ask a question, you should provide as much info as you think that might help. Just saying it does not work is like signing a blank cheque, there is no indication what is wrong.
1. Does the On/OFF switch indicate the cruise is in ready mode? If not, you need to check the fuse.
2. Is the brake pedal switch clerance properly adjusted?
3. Does meter cruise indiactor illuminates with the cruise not working?
SPONSORED LINKS
Sunday, November 23rd, 2008 AT 4:51 AM
