1999 Honda CRV steering wheel suddenly started jerking in e
1999 HONDA CRV
62,000 MILES • 4 CYL • AWD • AUTOMATIC
HBXFACTOR
hi ... here's supporting info to help diagnose issue:
my 1999 crv was fine this morning, then in evening the steering wheel would jerk or tick slightly at regular intervals while driving. i stopped and looked at tires, which were fine. just put air in them yesterday. hasn't done this before and doesn't seem like an alignment issue because it's not a constant pull.
is this somehow related to the groaning differential issue (just learned about online tonight, after 3 mechanics in 3 years couldn't fix it) that happens with sharp turns of the wheel? i read that major repairs are needed if that goes unaddressed for long time, and due to the suddenness of the wheel jerking, wondered if something finally went bad?
(PA inspection is current and i'd planned to take it for 60K reg service very soon -- now sooner!)
thanks for any suggestions
Jul 10, 2008 at 2:10 PM
KHLOW2008
  • 41,814 POSTS
Hi hbxfactor,
Apart from the steering, is there any other abnormalities?
I would suspect worn ball joints, steering linkages or loose wheel nuts.
Check inboard CV joints for lubrications.
Jul 11, 2008 at 4:39 AM
HBXFACTOR
@KHLow2008: Thanks for the response. Turns out it was the right front tire. Looked OK yesterday, but that was deceiving. Took it to shop this morning, and noticed a nasty bulge and worn tread (must've been hidden on the ground yesterday?) and it just blew out an hour after I left it there. Lucky I got it in there when I did and it didn't blow out while driving. New tire is on and all is smooth again with steering wheel. Thanks again for the response and have a great weekend. -- hbx
Jul 11, 2008 at 11:11 AM
