1997 Honda Civic P0420 Code
VEVEYA
1997 honda civic 100040 mileages.
my check engine light was on. the diagnostic trouble code is P0420------ Catalyst System Efficiency Below Threshold (Bank 1) , one repair technician told me I should replace a new catalyst converter, but another one told me to replace the new O2 sensors, what should I do? thanks.
Aug 13, 2006 at 4:59 PM
SERVICE WRITER
  • 9,123 POSTS
Have someone check the 02 sensor wave patterns on a scope or for being out of spec. In particular the front one. Converter is probably fine,but further testing should be done. If testing was done, not just a conversation, then you'll need to have faith in one of the techs. That code points to bank1-02 sensor. The front sensor evalutes gases before entering the converter and the rear one evaluates it after the converter
Aug 14, 2006 at 3:13 AM
Suggested Repair
Have the O2 sensor waveforms checked on a scope, especially the front bank 1 sensor, and compare them to spec before replacing parts. Further testing is needed; the catalytic converter may be fine if a sensor is out of spec.
Conversation Summary
A 1997 Honda Civic with about 100,000 miles has a check engine light and code P0420, catalyst efficiency below threshold on bank 1. One technician recommended a new catalytic converter and another recommended new O2 sensors. The expert advised scoping the O2 sensors, particularly the front sensor, and doing further testing rather than assuming the converter is bad. The front sensor reads gases before the converter and the rear sensor reads them after.
