2001 Honda Civic Timing Belt Due
Suggested Repair
Replace the timing belt now if you plan to keep the car. At 128,000 miles it is past the typical 80,000 to 100,000 mile interval. Exterior belt wear does not reliably show timing-belt condition, but this is an interference engine, so a broken timing belt can let pistons hit valves and require head replacement.
Conversation Summary
The owner of a 2001 Honda Civic EX coupe with 128,000 miles asked whether worn exterior belts indicate that the timing belt should be replaced and how often it should be changed. The expert said accessory-belt wear is not a dependable indicator, but the Civic uses an interference design, so a broken timing belt can cause piston-to-valve contact and require a head replacement. The expert recommended replacing the belt if the owner plans to keep driving the car, citing typical intervals of about 80,000 to 100,000 miles.
