I just had a bunch of belts replaced on my 1998 Honda Civic with 85,000 miles on it - timing belt, power steering belt,AC belt, and alternator belt. After having all that work done, I would expect everything to be really quiet. There is now a whirling noise, not there before the belt replacements. The mechanic explained this as the timing belt is nice and tight and needs to get stretched out a bit so that the grooves in the belt will fit correctly. He said the noise should go away after 100 - 150 miles. Is this really what's wrong and everything is working the way it should?
May 25, 2006 at 2:52 AM
