1998 Honda Civic Temp Gauge Rises
I changed the sensor at the thermostat, not sure where the other one would be located. Fan come's on, but car still warms up beyond the safe zone. Thanks again for the help.
Did you say that you replaced the engine thermostat or just the sensor located by the thermostat?
Did you say that you replaced the engine thermostat or just the sensor located by the thermostat?[/quote:9687e6a233]
I replaced the thermostat. The upper and lower radiator hoses are hot when the car has been running, I would guess that they are fine because liquid is flowing through them to cause them to heat up. I'm gonna do another flush tomorrow. Thanks for the reply.
Suggested Repair
Replace both coolant temperature sensors and recheck the fan relays. Also inspect for a collapsed radiator hose or radiator blockage, and flush the cooling system. Note that setting the heater to hot opens an extra coolant path and can mask restricted cooling.
Conversation Summary
A 1998 Honda Civic EX temperature gauge rises to about three-quarters while driving on the highway, especially when the heater control is set to cold, but stays nearer normal with the heater set to hot. It does not overheat while idling. The thermostat, radiator cap, and thermostat-area sensor were replaced, and the radiator fan operates. Experts suggested faulty coolant temperature sensors, fan-relay checks, a collapsed hose, or radiator blockage. The owner planned another coolant flush.
