1998 Honda Civic Radiator Replacement
Suggested Repair
Remove the old radiator and install the aluminum unit in reverse order. If the original radiator has a transmission cooler, the replacement must have one too, and Honda transmission fluid should be added. Fill the radiator and the overflow tank to the max line, run the engine to normal temperature, then slowly open the bleeder on the upper hose near the head until coolant comes out. Close it, drive the car, and recheck the coolant level and bleeder.
Conversation Summary
The owner of a 1998 Honda Civic coupe DX 1.6L non-VTEC asked how to replace the stock radiator with an all-aluminum unit and how to refill and bleed the cooling system. The expert said to reverse the removal process, match any transmission cooler and add Honda transmission fluid, fill the radiator and overflow, warm the engine, and bleed air at the upper-hose bleeder until coolant flows, then recheck after driving.
