2003 Honda Civic O2 Sensor Code
DOMINICANYOL
honda civic 2003 ex 22,000 miles
my problem is tha ive changed 02 sensor twice and still gives me the code and the ligh wont turn off ive tried reseting it but the light just comes back on i scan it and keeps on with the 02 sensor bad. please help
Apr 29, 2007 at 2:35 PM
BACKYARDMECHANIC
  • 337 POSTS
Are you changine the right one? You have a pre-convertor O2 sensor and a post convertor O2. If you are sure you are changing the right sensor then check the wiring to the sensor. A open in the wiring to the sensor will cause the check engine light to come on.
Apr 30, 2007 at 1:05 AM
Suggested Repair
Confirm the correct pre-converter or post-converter oxygen sensor is being replaced. If it is the right sensor, inspect the sensor wiring for an open circuit that can keep the check engine light on.
Conversation Summary
The owner of a 2003 Honda Civic EX reports that an oxygen-sensor code and check engine light return after two sensor replacements and resets. The expert advises confirming that the correct pre- or post-converter sensor is being replaced and checking its wiring for an open.
