how to adjust front disc brakes and adjust hand brake
HONDA CIVIC
SCOTT HOT ROD
1998 civic coupe EX 91,000 miles 4-cyl. standard engine size.
1. I had new rotors installed on front. The mechanic left the original pads and did not replace them. Is there a way to adjust the brakes to get better peddle feel when I apply the brakes or do I need new pads if the peddle goes to low?
2.How do I adust the hand brake?
Thank you-----Scott
Oct 12, 2007 at 10:30 AM
CHEVY22
  • 1,375 POSTS
hey scott you tech should have replaced the pads too they are fairly cheap and just good measure to ensure a good pedal , if they were just done it may take some time to seat properly , as far as the rear , the best way to do it is jack the car up remove the wheels and drums , clean the shoes and drums with brake cleaner .with the drums off you will see the adjuster , replace the drum remove the plug from the rear backing plate which will expose the adjuster . adjust the brakes while moving the drum to assure they arent too tight and your done , takes about 1/2 hour on the ground
jim
Oct 12, 2007 at 10:37 AM
