Hello there,
Thanks for the info.
Ok till I last filled it, ie on the 26th with coolent, this morning dead cold, I check the radiator, the level was not up to the top, but just slightly above the metal parts inside the radiator. But when I check the reserve the level was above the max, so Im not sure if thats the way its supose to be.
I started the car and drop wife off, only 10 min drive each way, got back, check top rad hose while engine is running, it was nice and hot and there is pressure on pipe, which to me looks preety good, ie coolent is circulating.
I check the exhaust but there isnt any white stuff and no smell.
The car currently is not overheating.I guess it overheated that time when I really was driving it fast for a while so maybe high pressure built up but im going to observe it till the overheating occurs again.
Also I notice that the fan intermittenly comes on. Id have the car on idle, rev up the rpm a lil bit for a while so that it would heat up so the fan would come on. Sometimes it wont come on. Ive changed the relay switch with new same issue, all fuses are ok. Could it still be related to a faulty themostat I wonder. The fan works for sure as I tested it.
Any thoughts on this car be great :)
Monday, January 30th, 2006 AT 12:13 PM
