Help, Daughter had a flat
WGRIMES
Need to ask a stupid question. My daughter had a flat tire on her 97 Honda Civic, 86,000 miles, 4 cylinder. How do you get the tire/rim off. How does she remove the cener "H" cap in the cener of the rim. She says her owners manual doesn't tell her how. She said there isn't a notch or groove to get the cap off. They removed the lug nuts but the rim won't come off.
Having not seen it, I'm at a loss.
Thanks in advance for your help.
Jan 27, 2007 at 3:00 PM
BRUCE HUNT
  • 3,754 POSTS
Once the lug nuts are off there is nothing holding the tire on. However, there technically is and it is called rust or corrosion. I would venture to say that the tire has been on awhile. I would take a rubber hammer and wrap the tire in a couple of locations along the edge. For a lack of a rubber hammer you can use you foot. Becareful not to get crazy and knock the car off the jack. But it should come loose.
Jan 28, 2007 at 1:29 AM
