1995 Honda Civic Heater Core Leak
Replacing the heater core is a good deal of work. Not sure the cost though as I have always done my own work.
A Honda dealer is probably going to charge 6.5 man/hours to change it and around $300 for the part. So all total it might be as high as $850 for a dealer to do. Some shops will beat that in price and if you get a core that is not genuine Honda parts it might save some.
As for if the core is leaking, turn your heat on and run it for a while. If the radiator fluid runs on the floor, smells like radiotr fluid, and your windows fog up a lot, then it is the heater core leaking.
If you are mechanically inclined, buy you a Chiltons manual, and follow it step by step and replace it yourself. Should take you a weekend of good work.
Suggested Repair
Confirm a heater-core leak by running the heat: coolant on the passenger floor, a coolant smell, and heavy window fogging point to the core. Replacement is labor-intensive; a dealer may take about 6.5 hours and charge roughly $300 for the part, up to about $850 total. Independent shops or a non-OEM core can cost less. A mechanically inclined owner can follow a repair manual and do the job over a weekend. Turning the heat off, or temporarily plugging the heater hoses at the engine, can stop coolant flow, but the leaking core should still be replaced.
Conversation Summary
The owner of a 1995 Honda Civic Coupe DX noticed coolant on the passenger floor only with the heat on and asked whether the heater core was leaking, whether A/C meant a shop job, and what it might cost. Experts said heat-off can stop coolant flow to the core and that the hoses can be plugged as a temporary measure. They advised confirming the leak by running the heat and checking for floor coolant, coolant odor, and fogged windows, then replacing the core. A dealer estimate was about 6.5 hours and up to roughly $850; other shops or an aftermarket core may be cheaper, and a careful DIY job with a manual could take a weekend.
